Help pls. triangular parametric facade
I am trying to make a triangle panel system for this geometry, Is there a way to make the triangles to be the same dimensions from the top to the bottom of the shape. I am using the lunchbox plug in but am happy for other methods to do this? I am trying to make a triangle panel system for this geometry, Is there a way to make the triangles to be the same dimensions from the top to the bottom of the shape. I am using the lunchbox plug in but am happy for other methods to do this!
TEST2.3dm (2.7 MB)
Test2.gh (4.2 KB)
Here is my script and rhino model thankyou
Hey,
Perhaps this can help.
[Inquiry] How to make a surface pattern transforming into a funnel shaped profile - Grasshopper - McNeel Forum
Check this as well…
Tri_Panels_re.gh (22.0 KB)
Hey, That was so helpful thank you so much. Just a quick question you may be able to help with further.
With the shape I am using, the tripanels only work with the U 8 and V 20, however im looking to get a more symetrical triangle, (with something like U8 V10), however if i change the tri panels to that shape it distorts the surface. (see picture 2).
Triangle Panels .gh (28.7 KB)
I have attached my script any infomation would be helpful thankyou.
