Help.... Docked panels always messed up
Hi everybody,
Rhino is driving me nuts. Since this afternoon every time I open Rhino (version 7.3) I have to rearrange all docked panels.
See the image below. Thats how Rhino opens every time. Then I put the Properties, etc panel under the Layers panel, and I switch sides of the ObjectSnap and Selection filter panels, and I want the commad line om the Left and Bongo timeline on the Right.
If I do all the arrangement and I close and reopen Rhino it’s again like this:
I tried running Rhino as administrator… doesn’t help.
Please, what can I do? I can’t work like this.
Thanks Tobias
I’m running an in-house development build which will become V7 SR5 and not seeing this problem.
I rearranged my panels so I have two docking containers, one below the other.
I did this with a single instance of V7 running.
I closed Rhino and reopened it.
It worked as expected:
Hi John, up to this afternoon it worked here too.
If you can come up with the circumstances required to repeat the problem, and if those instructions work for one of use here, then it can get added to the defect list.
Without that, there is nothing to be done.
How long has it been since you rebooted Windows?
Hi John, I tried to investigate a little. I know which file I opened and after it the problem started. I backed up my laptop and tried the same file there but on my laptop everything works just fine.
I also noticed that every time I restart Rhino the commandline / timeline together with the osnap / selection filter panel swaps sides. I mage a video to demonstrate it. Maybe it can help:
I know this problems are hard to tackle since you cannot repeat it, but maybe you have another idea I can try.
If not than I have to completely remove Rhino7 and reinstall it, and hope that it will fix it.
What would I have to delete to completely uninstall Rhino 7?
Thanks, Tobias
Ok, looks like I found the problem.
Today I cleaned my pc from everything Rhino 7 (registry, appdata, etc). Reinstalled Rhino 7 …problem still there. But then I had a look at the plugins. Only non stansard plugins were bongo and 2 denoisers.
I disabled the Intel and NVIDIA denoiser, restarted Rhino and everything was back to normal.
Then for a test I enabled the 2 denoisers again but Rhino is still starting normal. Hmm… so there is still a mystery somewhere. Maybe it’ll come back but the I know where to look.
The same of course for everyone encountering this problem. Check plugins first.
Anyway thanks John for your input.
greetins, Tobias
Very interesting…
@JohnM
@will
Any thoughts?
I have the Nvidia denoiser installed and running.
I’ve disabled my Intel GPU in Device Manager so there’s no reason for that denoiser on my system.
I have Bongo running too and no problem here.
Ok, I cheerd to early. I am back to the same problem. Turning of plugins doesn’t help.
Maybe you can try locking the Toolbars after you made your arrangement and see if that makes any difference.
Hi Gijs, I tried locking of the panels, and unlocking, open Rhino as administrator, etc… multiple times.
There must be something on my computer causing this. On my laptop things are working just fine. I also reinstalled my display driver… to no avail
I am quite lost. Don’t know what to try again. There’s no way I can work like this.
Just to be sure: have you got latest drivers? Is this hybrid system? Do you sometimes have multiple monitors attached? Did you try with a different monitor/ display port/ display port cable.
One other thing I can think of is to make sure all toolbars are from one rui by copying your Vray/Bongo toolbars to your default and then closing thoses rui’s (or at least turn off their toolbars) and make sure to save it under a custom rui name where you are sure to have all write access to.
I have the same issue since basically I can remember in Rhino, but have given up trying to fix it. I am on the latest Rhino 6 and it has been like that at least since the beginning of V6. Curiously it’s not ALL panels. But moving the layers panel and properties panel to different locations it opens them in the default position again EVERY time.
This sounds like something Rhino should be doing automatically. Shouldn’t it have one rui file and update that whenever I move a toolbar? I don’t understand why this is so difficult when I have not come across this issue in literally any other software and here it seems like a problem that people report regularly over the last few years.
Hoi Gijs, it’s really amazing how you can tackle a problem.
I am a little careful now to call it a solution, but the problem might indeed be related to my monitor setup. I have 2 monitors on my desk and the desktop is extended to a tv. So 3 monitors. If I disconnect the tv things seem to work (for now)
That being said, I don’t think this should affect Rhino in any way. So if this is the cause of the problem its clearly a bug. No other software on my computer suffers from my monitor setup.
All right, I keep on testing and keep you updated.
But absolutely brilliant thinking from your side!!!
greets Tobias
Ah good to hear you have at least found the source of your problem. I don’t have multiple monitors so hopefully others that do can chime in.
@seltzdesign I’m not sure if this is a solution to that, it was merely a suggestion to try out.
All right, I can officially confirm that my tv in a 3 monitor setup causes the problem.
My setup consist of 2x DELL 2408WFP (connected via DisplayPort) and a Samsung UE43TU8000 TV (connected by HDMI), powered by a GeForce GTX 1060 6GB
If I disconnect the tv the panels in Rhino behave normal. If I connect it again, the problem is back immediately. Btw… not every tv will cause this. For example there was no problem with a Phillips PUS8535. Also older Samsung models were just fine.
So it seems a pretty weird problem, but still Rhino shouldn’t be affected. To me it shows that the Rhino GUI is still “fragile”…
I solved this problem for now with a software called MultiMonitorTool (excellent little app). It allows me to quickly turn the tv off (as a monitor). I just turn it on when I need to view pc stuff on that screen which isn’t that often anyway.
Thanks again @Gijs for pointing me in the right direction. And maybe you guys at McNeel will be able to find out whats going on there.
greetins, Tobias
I’ve been having this problem since forever.
Sometimes Rhino just “decides” to rearrange the toolbars and it doesn’t need to be opened on a multiple monitors setup or a different PC. It just does it. On the same machine.
But yes - It mostly does it when I open a file on a different machine.
I’ve also given up on this bug as well.
May I once again call for a rework of the Rhino GUI?
A complete UI overhaul of Rhino would be a much welcomed move - Rhino / Rhino for Windows - McNeel Forum
No?! Ok.
Hi Toshe, this is a very old discussion, and for some users a rewrite of the UI it’s an absolute doom scenario. Like Rhino is dying or something. Anyway, in the end I don’t think McNeel is prepared to put any serious effort in the UI for the coming years, decades…
For me I don’t mind the archaic look. All I want is a GUI that works. Toolbars and panels that stay where I put them, and no flickering when scrolling panels…
That it’s possible is long proven by the Grasshopper interface.
