Rhino 7 - I customized my UI a bit and every time i load up Rhino it keeps slightly re organizing the panels…? Any help on making that not happen?
Hello - do you have one, or more than one RUI file open? It looks like one to me but just making sure (Options > Toolbar page)
And, are you using a single monitor or multiple displays? Here, arranging things as in your image sticks between sessions so far.
@whitie925 , can you provide the exact Windows build information from Windows’ System Information?
Hi Pascal,
Many thanks for the helpful info. I wasn’t aware that you could have more that one rui open…? What would be the point of that?
I did notice that when rhino opens… if i select a template then things open fine with panels in the correct position… if i let rhino open the default template on its own, it re arranges the panels… Is this odd?
Yes. Thanks for that detail.
@whitie925 - are you selecting a template from the splash, when it works right? And, if you open Rhino without selecting a template, is it opening with a default template that you’ve previously set,
or truly no template at all?
Hey @pascal - Reviving this b/c I’m running into same problem, with toolbars not sticking where they should, after many a month of them being fine. They do go back to the “same wrong” position, which is like my computer sticking its tongue out at me ![]()
Recent changes:
I believe I do have multiple RUI’s going on here, but truthfully, I’e always been a bit confused by the toolbars, groups, rui, etc. And I do have two monitors going, and two GPUs (though one is RTX2070 and one is RTX3060) with one monitor in Portrait mode. This is not new, though.
Thoughts?
EDIT: Was able to basically start from scratch (closing a bunch of the toolbars in the Options window) and then reopened one by one. Seems to be working ok now. Think it’s maybe some unique quirk?
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Commercial, build 2022-05-04
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 4-20-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.59
Secondary graphics devices.
NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 4-20-2022 (M-D-Y).
- Secondary monitor attached to adapter port #0
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 1-22-2020 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-20-2022
Driver Version: 30.0.15.1259
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.3\Substance.Win.rhp “SubstanceImporter” 2.0.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
Hi Alan - can you post a screen shot of Options > Toolbars?
Hi Alan - what might help is to
THanks, I’ll try that.
Follow-up (and apologies if this is a sep topic):
I have a “Pop-Up” toolbar I made, but it’s in a diff Toolbar (Group?) How would I go about getting just that grouping (small-g) into my default_Alan.rui?
EDIT: Do I make #2 happen from the Workspace Editor, or from the Toolbar Option window?
EDIT: Ah, hate when I figure something out after asking! – For others, here’s what I learned:
Hope my being a dumb-dumb about this ends up helping someone else ![]()
