My Graphics Device isn't being used?
I having difficulties with my graphics card being used by Rhino. My device is not rendering models correctly and it says my NVIDIA RTX A4500 GPU is not being used, which I think is the problem but no matter what I try I can’t seem to get it to work. I have checked for updates, installed, and uninstalled, and been trying to read on how to fix this issue, any suggestions??
This is my system information.
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Educational, build 2023-12-12
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Secondary graphics devices.
NVIDIA RTX A4500 Laptop GPU (NVidia) Memory: 15GB, Driver date: 1-18-2024 (M-D-Y).
- This device is not being used
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-16-2023 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 15 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
Hi Paige - I think the ting to do here is a full clean install of the GPU drivers. When you install, make sure you use the clean install option.
hi! thank you for the suggestion i ran a full clean install again but nothing changed. :confused:
@jeff -Hi Jeff - do you have an idea?
See if this procedure helps:
Any luck?
No… I followed those steps and nothing has changed
I suspect y0our computer was imaged incorrectly by the maker.
My best recommendation is to contact them about getting the hardware and drivers they installed working correctly. This might involve deleting the Nvidia display adapter in Device manager, and letting Windows discover it again.
I wold not do this before contacting the laptop maker.
Rhino 8 supports the RTX A4500. I’ll have to build a file specifically for this device. I’ll look into it right now.
@Paige1 can you please run the Rhino command RhinoCycles_ShowDeviceCapabilities? Once run press F2, then copy and paste the output of that command here please. As far as I can tell it should work already. At least my RTX 4000 FSS Ada gen which is newer than your GPU works with Rhino 7.
When you say “it says my NVIDIA RTX A4500 GPU is not being used” where exactly do you see this information?
Any other “Secret Commands” to shine light on this issue? The SystemInfo contains this paragraph: ATTENTION:
