Edge Softening Issues
Hello @Gijs, here and with Cycles same or similar issue reported in this VRay post:
Issue reported many days ago which persist with last updates too:
Another possible issue with Soft Edgening changing Display Mode: Raytracing shows the previous Mat:
EDIT: Sorry must have been an issue recording the Video. With a PBR Mat and Soft Edgening when I change Display Mode from Render to Raytracing, this one shows the previous Mat
I remember that linked to Edge Softening there is a Texuture Mapping issue already send to study RH-81433
Repported here:
and here
SystemInfo.txt (2.0 KB)
Thank you, regards,
Bartle
Another tried, may be an issue on uploading
![Edge Softening Issue|video](upload://artInrIQlOF9znVdINrD6ejXNKy.mp4
There must be a problem with the video, Sorry
Thanks for correction @martinsiegrist
Your link was only missing a curved bracket ) at the end
Thanks for info, unfortunately the video doesn’t run as it would, I have lost all the procedure, I need to find a video recorder, XBox Game Bar doesn’t record Menus, VLC seemed to run ok, may be I have made a mistake elsewhere.
I will take another try,
Thank you very much,
Bartle
I’m using OBS to create screen captures and Autohotkey to visualize mouse clicks and key presses.
@Bartleboom pls send _SystemInfo, as I cannot repeat that issue in my current 8.8 build.
Thank you @Gijs
EDIT: like I wrote here
It seems depending on when one apply Edge Softening
