Display issues with Rhino 8
I seem to be having an issue with pop up menus not showing up or hesitating. Sometimes it takes two to three tries just to get something to show up and if I move my mouse cursor over the area where the popup should be the rest of the buttons appear. Its become quite annoying. Any thoughts?
Windows 11
Nvidia RTX 5090 graphics card.
Full specs below.
Rhino 8 SR32 2026-6-9 (Rhino 8, 8.32.26160.13001, Git hash:master @ 2804b73b0f4b4feba10cb8b0b07c18fce290de93)
License type: Commercial, build 2026-06-09
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 62GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5090 (NVidia) Memory: 32GB, Driver date: 6-11-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.62
Accelerated graphics device with 4 adapter port(s)
  • Secondary monitor attached to adapter port 0
  • Windows Main Display attached to adapter port 1
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 2GB, Driver date: 3-3-2026 (M-D-Y).
Accelerated graphics device with 5 adapter port(s)
  • There are no monitors attached to this device!
    ASPEED Graphics Family(WDDM) (ASPEED) Memory: 64MB, Driver date: 5-13-2025 (M-D-Y).
External USB display device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-11-2026
Driver Version: 32.0.16.1062
Z-Buffer depth: 24 bits
Total Video Memory: 32607 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.32.26160.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.32.26160.13001
Hi, @FilmDesigner. Have you gone through these steps, yet? They’re helpful, even for desktops.
I’d also make sure you are using the latest NVIDIA “Production/Studio” driver for your 5090 card. Is the AMD Radeon a secondary card you can take out or built into your motherboard? If a secondary card, just take it out of your system. I’d also recommend temporarily detatching any monitor other than your main monitor (which should be plugged into your NVIDIA card).
One more thing I recently found on my laptop was I was using a Windows power management feature that defaulted to less performance. Double-check what your power management scheme is in Windows, and make sure it’s set for high performance.
Let us know how it goes.
Thank you ! Ill look into those things. Im on a desktop system not a laptop but perhaps there is something in that info that will help.
That worked! Thank you again.
s
Excellent. For future readers, which part specifically worked for ya?
I followed the instructions from Kyle adjusting the display settings.
Well, I spoke too soon. It seemed to be better but its still giving me problems. Not as often as before but its still doing it. I guess I will keep investigating.
One odd thing is I turned off my second monitor and my PAN function stopped working so there is some strange behavior going on.
I searched for similar issues just to see if it can give any clues, gives me couple results to try:
GPU drivers corrupted: reinstall
Hardware acceleration: turn off
Old BIOS version: update bios
Also i see you have 2gpus check if rhino is running on the 5090
GPU drivers are up to date
Ill check hardware acceleration
Bios should be up to date its a brand new system.
Rhino is running on the 5090
Whats odd is Rhino is the ONLY app thats having this issue. Blender, Modo and Photoshop are all functioning normally.
i cant seem to replicate i hope its not hardware related with a gpu like that its pricey!
you are on SR32 im on 33 maybe try and update? just throwing ideas to try
funny i found an annoying bug i thought was fixed again ill have to make a seperate post lol
well it better not be the GPU. Its brand new.
I just updated to SR 33 no change.
Checked Nvidia settings?
i dont have anything crazy other than this setting
I went through the checklist Kyle posted on the forum and is linked above. Its sort of worked for a short time but it seems to be acting up again. I changed that setting in the Nvidia settings , no change.
Bummer..:face_with_diagonal_mouth:
