I have 2 minor annoyances when dealing with Rhino 8.
Middle mouse click when pushed and the cursor is still moving - The toolbar does not render properly. I have to either click off again and middle mouse click with the mouse perfectly still OR I have to use the mouse and run over the buttons to get them to show up. Is this a known issue?
Every couple of minutes. Rhino 8 simply just… locks up for around 2 seconds. Quite disturbing for worksflows. Any run in to this, yet? At the time the glitching is happening. Very little resources are being used.
Yes, I quite literally JUST opened a blank and scrolled in and out and almost immediately a roughly 2 second lockup occurred. This syteminfo was pulled directly after that lockup:
Rhino 8 SR32 2026-6-9 (Rhino 8, 8.32.26160.13001, Git hash:master @ 2804b73b0f4b4feba10cb8b0b07c18fce290de93)
License type: Commercial, build 2026-06-09
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 62GB)
.NET 8.0.15
Accelerated graphics device with 5 adapter port(s)
There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-2-2026
Driver Version: 32.0.16.1074
Z-Buffer depth: 24 bits
Total Video Memory: 16303 MB
Right-click AMD Radeon™ Graphics and select Disable device (or disable it in your motherboard BIOS).
Since you’re using desktop GPU, this ensures Rhino 8 and Windows handle display rendering strictly through the dedicated NVIDIA GPU without conflicts or display state switching.
Set High-Performance GPU Preference in Windows:
Go to Windows Settings > System > Display > Graphics.
Find or add Rhino 8 (Rhino.exe).
Click Options and explicitly set it to High performance (selecting the NVIDIA GeForce RTX card).
I cannot disable the iGPU as i actually use it for separate rendering on another program. I have already made sure that Rhino is set to max performance (RTX 5080) in the graphics settings! Thank you!
I don’t see either of those issues. Here are some things you could check out that might be responsible for your system being different.
I’d suspect the mouse more than the idle GPU. Have you got another mouse you could try? Does your mouse driver need checking?
Do you have a housekeeping task running that grabs/locks resources every two minutes, like backups, file indexing, antivirus? Are you working off a network or cloud drive (OneDrive etc)? If you check the event log, do you see regular errors being logged?
HTH
Jeremy
p.s. You could disable the AMD card long enough to confirm whether it is involved and then reinstate it. Always good to actively eliminate possibilities.
I see that you are using your iGPU similarly to my setup.
I found that Windows GPU auto and manual pick under GPU Preference, gives different results. I was experimenting with it to find the best settings for my Rhino 8.
Instead of letting Windows decide, I tried every single combination available with my setup. Tends that picking specific GPU for Rhino (mine is AMD) gives different result if we let windows decides or selecting power saving.
I tried Rhino with RTX 3060, A4000 and A5000 each, but it gives me what I need when I select it as Specific GPU to the AMD.
Try to assign it as Specific, instead of High Performance. I personally avoid those Let Windows decide, Power Saving and Best Performance.
