Rhino 8 render not showing Nvidia GPU. Rhino 7 does
Neither Rhino 8 nor the R9 WIP show the GPU tabs on the Render Options page. Notwithstanding the 5070 laptop GPU arrived after Rhino 7, the latter does list it, so it is difficult to see why the later releases have a problem with it.
SystemInfo:
Rhino 8 SR31 2026-4-14 (Rhino 8, 8.31.26104.08181, Git hash:master @ 2b632c545519ecab0a6a691f560dfcc31eac2d65)
License type: Commercial, build 2026-04-14
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.26
Primary display and OpenGL: NVIDIA GeForce RTX 5070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.79
Primary OpenGL: NVIDIA GeForce RTX 5070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.79
Secondary graphics devices.
Intel(R) Arc™ 140T GPU (32GB) (Intel) Memory: 2GB, Driver date: 4-16-2026 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-4-2026
Driver Version: 32.0.15.9579
Z-Buffer depth: 24 bits
Total Video Memory: 8151 MB
C:\Program Files\Bongo 3.0 (64-bit)\BongoEtoUI.rhp “BongoEtoUI” 1.0.0.0
C:\Users\jeremy\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.6.0.0\bella_rhino.rhp “Bella” 24.6.0.0
C:\Program Files\Bongo 3.0 (64-bit)\Rhino8\Bongo.30.rhp “Bongo 3.0”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.31.26104.8181
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.31.26104.8181
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.31.26104.8181
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.31.26104.8181
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.31.26104.8181
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.31.26104.8181
Is cycles enabled?
Hi @Japhy,
Yes, I realised there was an issue when I saw that a render I started was using the CPU.
There are reports of issues with nvidia drivers on applications after windows updates
The typical troubleshooting steps to apply are:
  1. Clean install of the latest Nvidia driver (in the Custom section of the Nvidia installer)
  2. Repair Rhinos
  3. Disable Bella (not likely.. but typical troubleshooting)
  4. more drastic would be to uninstall the card via Device Manager
Hi Japhy,
I’ve done 1 to 3 for Rhino 8, rebooting after each, and still don’t see the GPU tabs. Given that the GPU tabs are present in the R7 render options page, and the card shows in the R8 SystemInfo, I feel that the issue is within Rhino rather than the GPU and/or drivers, and so I’m not keen to do 4…
I have also tried reverting from latest Intel and Nvidia drivers to the latest Lenovo distributed variants in case there were machine-specific tweaks but that made no difference to the problem.
I’ve also checked my desktop PC and there the GPU tabs show up, with my gen 2 and gen 3 cards shown.
Hi @jeremy5,
There are two command that may help here.
RhinoCyclesDisableGpu
RhinoCyclesEnableGpu
When RhinoCyclesDisableGpu was run, and Rhino WIP reopened, this is what my Rhino Render options looked like:
When RhinoCyclesEnableGpu was run, and Rhino WIP reopened, this is what my Rhino Render options looked like:
There may be more going on here “under the hood” so just a stab.
Let us know if this helps or not.
Sincerely,
Mary Ann Fugier
Hi Mary,
Thanks for the suggestion. Unfortunately it didn’t help in this case.
Regards
Jeremy
Hi @jeremy5,
could you send me the output of the following 4 command, please:
RhinoCyclesShowLog, RhinoCycles_ListDevices , RhinoCycles_ShowInfo and RhinoCycles_ShowPaths.
Thanks.
-Lars
Hi @lars,
Here you go:
RhinoCycles_ListDevices.txt (149 Bytes)
RhinoCycles_ShowInfo.txt (212 Bytes)
RhinoCycles_ShowPaths.txt (392 Bytes)
RhinoCyclesShowLog.txt (773 Bytes)
Regards
Jeremy
And here, in case it is useful, is a longer log…
RhinoCyclesShowLogLonger.txt (5.2 KB)
We had a similar report, rolled back Rhino and Drivers to no success. Is there anything in the Windows Event Watcher during Rhino startup?
Hi Japhy,
I started Rhino 8, took it to the point where I opened the render options page and saw no GPU-related tabs, then checked the event logs for that period of time. I saw nothing that raised even a glimmer of suspicion it might be relevant. In fact, having worked with Windows since its inception, this is probably the most benign set of event logs I have ever seen. Sorry!
My laptop is a Lenovo Yoga Pro 9 - what machine was involved in the other report?
Regards
Jeremy
Lenovo Legion, I’m wondering if this is one of the cases where an overlay (nvidia setting) or something like that could be interfering.
one thing you can try is closing Rhino and deleting the content of..
%APPDATA%\McNeel\Rhinoceros\8.0\Plug-ins\RhinoCycles (9bc28e9e-7a6c-4b8f-a0c6-3d05e02d1b97)\data
%APPDATA%\NVIDIA\ComputeCache
I’m away from my computer now but I’ll try the deletions later.
The laptop is set for Windows to choose which graphics card to use except for apps nominated to use Nvidia. These include R7, 8 & WIP. Setting the laptop to use Nvidia exclusively for everything doesn’t help.
Deleting those folders hasn’t helped.
Did you use the Lenova Vantage app to change the setting?
No, the Nvidia Control Panel. I don’t think that setting is available in my edition of Vantage.
Also, let’s not lose sight of R7 working OK…
Is there by chance a file called “disable_gpus” in this location “%APPDATA%\McNeel\Rhinoceros\8.0\Plug-ins\RhinoCycles (9bc28e9e-7a6c-4b8f-a0c6-3d05e02d1b97)\settings”?
If there is close all running Rhinos and delete that file.
Hi @lars
That file is present and is zero bytes. I deleted it but when Rhino 8 subsequently started it recreated the file.
The R8 started after deleting the file still does not show the GPU tabs.
Regards
Jeremy
I also find it curious, given it is apparently fixed now, that Rhino also doesn’t see your Intel Arc 140T as a valid render device. As OneAPI has been shown by at least one user to be fixed on his 140V for both Rhino 8 (and WIP I assume), then I would expect the Arc to show as well.
