When I tried to drag the panel, RhinoWIP stopped running!!!
The relevant documents are attached at the back.
systeminfo.txt (3.2 KB)
RhinoDotNetCrash.txt (1.0 KB)
Can you have a look here and see if your problem is related?
I tested the solution in the link, but the problem remains unsolved.
RhinoWIP cannot operate when I drag Command Bar
And the following files appear on the desktop
Hi -
Please make sure to test with the new WIP that was released yesterday.
Could you please run WindowLayout and restore the Default Window Layout and then try this again.
Also, from your video, it looks like Rhino hangs but doesn’t crash. If that is the case, could you please create a manual dump file and send that in? The process for doing that is described here: Manually Creating a Memory Dump (DMP File) from an Unresponsive Rhino for Windows [McNeel Wiki]
Thank you!
When I use the latest WIP,everything works fine。
