Jarek
December 6, 2017, 11:51pm
1
I can’t get it to work here in V6: Any display mode with XrayAllWires ON assigned per-object doesn’t Xay the wires in other global view display modes. It works OK in V5.
We need only certain objects to xray wires and SetObjectDisplayMode used to do the job.
thanks,
–jarek
wim
(Wim Dekeyser)
December 7, 2017, 7:31am
2
FWIW, that seems to work here.
(6.0.17339.19241, 2017-12-05)
Jarek
December 7, 2017, 7:45am
3
Thanks @wim . Now I see that it doesn’t work with Curve object types. Breps/Meshes work OK.
A simple step by step here to try:
Switch Vport to Rendered mode
Draw 2 boxes and a Curve
Edit Shaded mode to have XrayAllWires
Use SetObjectDisplayMode > Shaded on one box and the curve
Now you will see that the box shows the wires through the 2nd box, but the curve doesn’t.
wim
(Wim Dekeyser)
December 7, 2017, 8:14am
4
Ha! Then it sounds like this one:
Setup:
Factory-default display mode Shaded [or any other for that matter].
Modified display mode Wireframe: [… > Wireframe > Objects > Curves > Curve Settings > Curve width (pixels): 6] – or any number that makes the effect very clear.
Scene with any number of objects but at least one curve.
Viewport display mode: Shaded.
Steps taken:
Select the curve and run SetObjectDisplayMode.
Select the modified Wireframe display mode.
Observations:
The curve appears to remain in the Shaded display …
Perhaps just add a comment to RH-42692 ?
Jarek
December 7, 2017, 8:21am
5
I just did-
I see now there is more issues with curves and SetObjectDisplayMode…
For me it’s a bug though, not a buglet
