SetObjectDisplayMode buglet
Setup:
  • Factory-default display mode Shaded [or any other for that matter].
  • Modified display mode Wireframe: [… > Wireframe > Objects > Curves > Curve Settings > Curve width (pixels): 6] – or any number that makes the effect very clear.
  • Scene with any number of objects but at least one curve.
  • Viewport display mode: Shaded.
Steps taken:
  • Select the curve and run SetObjectDisplayMode.
  • Select the modified Wireframe display mode.
Observations:
  • The curve appears to remain in the Shaded display mode - in this picture, one curve was assigned the modified Wireframe mode.
  • When selected, the curve is clearly displayed using the modified mode:
YouTrack issue: RH-42692
Hi Wim - thanks.
