Worksesion-Layer State can’t retain ModelOn/LayoutOn/DetailOn, default On
Project Context:
Whole building architectural project, 5 story 40k sf mixed use residential building. Worksession is 15 files, one file is a “CD set” of Layout sheets with detail views (set to named views set by clipping planes) and annotations.
Problem:
The Worksession cannot maintain visibility settings across model space, layout space and detail views. When opening the .rws file or after updating a linked .3dm file, visibility settings clear themselves and need to be manually reset. It made modeling the building a little annoying but has made the architectural documentation process a nightmare.
Process:
-ModelOn/LayoutOn/DetailOn/GlobalOn are set in every linked file before save and close.
-Initially opening the .rws file; individual linked file ModelOn/LayoutOn/DetailOn settings clear themselves but generally the GlobalOn settings are retained.
-After resetting ModelOn/LayoutOn/DetailOn/GlobalOn settings based on the intent of the active Worksession file create a Layer State to try to preserve settings.
-Update a linked file in the Worksession (by either the manager window or by right click layer>work ref>update) causes ModelOn/LayoutOn/DetailOn settings of that file to clear themselves in the .rws file model space, layout space and in every detail view.
-Restore a layer state, just reshuffles the On/Off settings, doesn’t restore anything but some GlobalOn.
-To correct it after any update, you need to reset LayoutOn/DetailOn setting in every detail on every layout. SUCKS! This would only be an challenge if the default setting was Off but when every layer in every file defaults to On, this becomes a professionally unusable tool.
Using Active/Referenced layers on a linked block will keep the detail overrides.
Unclear what the intent was in your reply. Are you recommending people set Layer Style to Active or set to Reference? You seem to be saying my problem was not choosing one, which isnt possible.
Regardless, I have tried both Layer Style settings. I have tried all three Block Definition Type settings. I have also tried various combinations of Layer Style and Block Definition Type settings. Nothing I have tried maintains Detail Off selections.
Are these not retained when using a linked block with active layers? These also respond to a Saved Layer State
RE_Detail_Layers_Layout.3dm (55.9 KB)
RE_Detail_Layers_Base.3dm (44.8 KB)
