I know there has been past issues with Layer/ Detail visibility settings (ON/OFF) in viewports. The layers are not saved in the .RWS file and when reopening all Active Parent Layers are enabled.
Did this get resolved in R7.0?
Thanks,
Thanks,
Hi Daryl -
That sounds like RH-37146 which hasn’t been fixed in Rhino 7.
Im hoping that will get resolved. If there isnt a way for Layout settings to be saved it is a huge problem that negates a large majority of the worksession benefit.
Please keep us posted on this.
Thanks Very Much,
Daryl Wilbur
I agree with Daryl, the worksession feature is unusable for me without layout detail functionality!
Workaround while the fix gets published: you can use the Layer State Manager after you load/reload the worksession.
I tried this, but it hides the layers in the model space as well, it’s only supposed to do it in layout space.
I just wanted to reactivate this thread because we’re still running into the same problem. In our Rhino Worksession setup—with several .3dm files attached to a main .rws file and one file dedicated to layout and printing—the “Detail on” settings in the Layers panel just won’t stick. Every time changes are made in the attached files and we reopen the layout file, all the “Detail on” settings reset back to “on.” This wipes out any custom visibility setups for our multiple layouts, messing up the entire printing workflow and rendering the approach useless. We also have a need or an idea about having global settings—like line weight—that could be applied across every attached file.
Edit: I am running RH8
@jsbzh Are you asking about Rhino 7? No enhancements to Rhino 7 are expected. Rhino 8 is the current version.
Sorry, yes good hint. I am running rhino 8.
You may want to start a new thread with your question. Mention you are using Rhino 8 or post the results of the Rhino command SystemInfo.
