With Osnap set to temporarily enable via an ALT key press.
During a curve command for placing the next point I need to temp enable Osnap to place a smartTrack point on a neighboring curve. While ALT is pressed, the CTRL key doesn’t create a smartTrack point.
I think it is a good idea to be added to the wishlist
Disable Osnap is not allways essential → Switching with RMB is easy.
Hover mouse over one snap method, click RMB all other method gets deactived, click again all get activated.
Other combinations are possible, depending on click…
I use RMB for other things and never want oSnaps activated by default. They always interfere at the wrong moments in dense models.
