Description:
In shipbuilding we position everything relative to a ship grid.
For example “F42 + 150” for a frame, “W6 − 200” for a longitudinal, and “D3 + 50” for a deck.
Today we have to convert these positions or grid distance to coordinates before using the Gumball.
Proposal:
Add a Grid definition section to Options > Modeling Aids > Gumball:
Reference: World CPlane, or a selectable named CPlane.
Per axis (X / Y / Z): define a prefix Prefix (for example x => F, y => W, Z => D)
Grid line positions, either as a regular spacing or as an explicit list for irregular spacing
I used for some projects the document usertext to specify the grid
For example:
FrameGrid_Origin 0
FrameGrid_Spacing -20,600:20,800:150,700:250
HeightGrid_Origin 0
HeightGrid_Spacing -1,1000:0,1800:1,2800:20
WidthGrid_Origin 0
WidthGrid_Spacing -20,700:-10,650:10,700:20
For frames it means:
from F-20 => F20 the grid distance is 600
from F20 => F150 the grid distance is 800
from F150 => F250 the grid distance is 700
The FrameGrid_origin is on 0
But in shipbuilding it is possible the Grid F0 isn’t on Cplane position X=0
Therefore i use a grid shift value.
Gumball behaviour when a grid definition is active:
I like to move or copy some objects in a certain direction.
For example by a value F1 or F1+20 or F1-20 or F1.5 or F5
Depending in the position of the object by F1 it could shift 600,800 or 700 mm
I also like to have the posibility to shift or copy to an apsolute position by using A0 cplane x=0 or AF0 Frame 0
And make multiple copys with a certain distance for example:
1000:5 => 5 copys with a step of 1000 units
F5:5 => 5 copys with step of 5 frames depending on object position.
If this isn’t possible than is there a way to read and modify the given input by a script
to get the move or copy input distance to your wish.
