Wish: Export Layout to dwg
it is great that Rhino 8 now features the clipping plane (section) hatches, thanks !! :+1:
now would be great if Rhino allows to export (or print) a layout into dwg
since it allows to print pdf as vector, it should be (I hope) easy to do the same to dwg. The hatches could export as blocks (each hatch as a separate block, and into a layer eg. Layername_hatch)
than it would work as in Archicad, where you can also export layouts into dwg
since the layout has clipping planes assigned, the section hatches assigned, it would be more easy than doing the current routine (which is apply all clipping planes to Model view, doing Make 2D etc…)
hi Jan,
there are already a couple YT items for this (some not public), but it’s not something that you can expect soon.
RH-38481 Layout: Save all layouts as DWG
RH-37630 New Command: ExportLayoutToDXF
Try out the new FlattenLayout command (work in progress detailed in the post here).
Any feedback will be very helpful to us.
Bill Cook
McNeel Development Team
