IMO printing to DWG should be an options just like printing to PDF.
Please consider it, Layouts are produce of Rhino and having the option to do more with it would be great.
Using PDF as a workaround isn’t a good option as hatches are divided and curves are segmented by the PDF printer.
PS! The workaround I used now was change space all the data, but then the scaling of the dimensions and the text had to be changed too, so not a smooth workaround. And if I had used more advanced options like “hide in detail” to reuse the detail in other layouts, then it would have been a lot of extra work.
