So i get a message saying an update has been downloaded.
So i go to install it, but get errors, including the attached, at which point the progress bar goes backwards (!) which I’ve never seen before and is kind of cool, but what now…???
Wow! Sounds like the kind of thing I’d expect from malware. I know it’s a WIP, so strange things can be expected, but are you sure it’s genuinely from McNeel?
I’m seeing a similar problem her. After the auto-update rolled back, the .msi file seems to have vanished. Once it’s downloaded again, I’ll post the log. For now, maybe the error messages may help.
Okay, now starting the msi file from the command line required a “clean” install including me entering the license key again. Everything seems fine with the installation. No error messages, Rhino WIP starts up with all plugins. (apart from a localization error, I am reporting separately)
soo… the error pops up when updating from inside of Rhino. Maybe @rabbit can confirm that.
@brian If this pops up again, is there any way to generate a log for the updater from inside Rhino?
