Hi, in my Dell Xps 15 I used Rhino6 with no issue until the last Windows Update (July '19). Now when opening Rhino, after a couple of seconds the whole windows system get freezed (no use of mouse, keypoard or touchpad); the only solution is to force the laptop shutdown manually using the external button. It seems related to the use of the use of a Hybrid graphic system, with 2 cards (Intel + AMD Radeon), since if I disable the first one, Rhino seems to work, but with lower graphic performance.
NB: the Graphic Cards drivers are the last update.
Render version: 4.6
Shading Language: 4.60
Driver Date: 12-6-2018
Driver Version: 25.20.15002.58
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Hello - you should be able to force a âHigh performanceâ mode on the graphics system so that it uses the AMD card only. If disabling the Intel gpu results in poor performance (did I understand that correctly?) then Iâd guess Rhino is not seeing the AMD at all. What does your Options > View > OpenGL page show you about the video?
In the past there have been many reports of Windows Update, which seems to have itâs own idea of what is the latest video driver, installing an older driver than what youâve been using. Could this have happened to you? I notice your AMD driver is from 12-6-2018. Do you know what it was before the Windows Update, and whether it is actually the latest available from AMD?
@AlW , thanks. This is actually the last version. About the AMD, even if on the website it is written Gen-19, after the installation it shows Dec-18. To be honest I donât know the older version installed, and the Roll Back Driver option is now disabled
Hi, the problem seems to be solved, thanks!
Here some comments for people having the same issues:
Basically no problem about unistalling and reinstalling the AMD-drivers. About the Intel-drivers, it was a little tricky: there are problem installing it from the Intel website (found different error messages), I had to install it from the DELL website update service, which in the end installed a different driver release (to the last update). Here the âworkingâ system settings:
Method to update Intel graphics drivers with the latest from Intel
Rhino 6 likes up to date video drivers, and âupdate your video driversâ is a frequent refrain on this forum. However if you have an Intel graphics adapter which was originally furnished with a âcustomizedâ driver it may appear impossible to update the driver with the latest from the Intel website.
I have found a method to get around the blocking of the driver update and manually install the driver update. The key is to use Device Manager to uninstall the adapter after checking the box to delete the software for the device. The adapter then disappears from Device Manager but will reappear after a âScan for hardware changesâ. The new driver can then be installed manually through Device Manager.
Attempting to update the driver through Device Manager without uninstalling the device and deleting the software resulted in a message that the âbest softwareâ was already installed and termination of the update process. Similarly attempting to manually install the updated driver after deleting the device but without checking the remove software box resulted in the device and old software being automatically reinstalled when the computer restarted.
