I am changing the layer of this object and it won’t render the material I’ve applied to that layer…
Was originally built in sketchup and imported into rhino.
Test.3dm (2.2 MB)
Test.3dm (2.2 MB)
Through Object properties go into the material tab click on the material and select By Layer. Only then will the object use the layer material on which it is.
Great thanks!
