Problem of rendering material to layers not applying to layer objects
Problem assign rendering material to layers or making them visible in the rendering view.
I can apply material on individual objects.
I read somewhere that it could be a setting in the advanced settings in Options.
Any suggestions?
Hi @nilceros ,
You can assign a material to objects on a layer via the right click menu over a material swatch in the Materials panel. Do you have a simple sample file where this isn’t working that you can reply with here? Is the active renderer Rhino Render as well?
Hi thanks for the reply and sorry that I missed it. I think it was some kind of temporary bug (?) cause i couldn’t change the material via the objects material drop-down menu but it was possible
assign via the materials panel assign selected
