Hello.
I think Revit 2026 version has been released. When will RIR be able to work with Revit 2026?
Hello.
HiJbk9229,
Coming Soon! Although I don’t have a firm date for you.
Note that it will be available in the Daily build first before getting into the Release Candidate.
hi, @Japhy, were can I find that daily build. I’m running out of days to try revit 2026. Cheers
Good!, thank you. I was waiting for this news.
I tried to install the daily version but it failed.
I went into REVIT2025 version and downloaded the Daily Build.
There is no 2026 in the installation process and even if I install it, it doesn’t appear in 2026.
Question.
RhinoInside.Revit_1.32.9217.15361.msi
Is this the current daily build version?
Oh, I think I misunderstood what you said. It doesn’t mean that the current daily build version can be used in 2026, but that the daily build version is the one that updates the fastest.
Please test Rhino.Inside - Revit 2026 in the latest Daily Build WIP download.
Note that there are Revit API changes with each release that may impact existing workflows.
The latest Daily is 1.32.9245.4693
I installed RhinoInside.Revit_1.32.9245.4693 (it shows that is installing also for the 2026 ), but it is not loading
Rhino.Inside Revit requires Rhino 8 to run on Revit 2025 and 2026.
yes i have rhino 8
Hi @Japhy , recurring issue as I cannot see the Rhino Inside Revit menu in Revit 2026.
I have Rhino 8 up to date.
Revit 2026 Trial version installed 2 days ago.
RhinoInside.Revit_1.29.9186.27799
Nothing shown in Add In manager
I have tried to install / uninstall a few times with no luck.
Would it be possible to have access to 1.32.9245.4693 please?
Thank you
Pierre
Sent. If the only version of Revit you have is 2026 you will need to ask for the installer, its currently only available in the Daily WIP build. Thanks
Where can I download it
