RhinoInside.Revit is not loading up when I start Revit. It says I need to update Revit but it is already on the latest version and meets all of the plugin’s requirements.
I was previously able to use RhinoInside.Revit. This issue only showed up when I had to reinstall the beta version after the 45 day period. Is anyone else facing this issue? Thank you for the help.
That’s fine. Save the file in the new version. Any components that can be upgraded will remain, if not they should have a white box where they were, then replace with the new improved versions.
Built-In Category picker instead of Model Categories Picker for example.
If you read there error its expecting Revit 2021.1 as well.
