Installing Rhino Inside Revit with Revit Trial Version (Unregistered)
Hello
I am running Rhino 7 and a Trial Version of Revit 2024. I installed Rhino.Inside, but when I open Revit it does not ask me if I want to load Rhino.Inside, and I do not see any sign of the Rhino toolbar in Revit.
Is it simply because I am running a trial version of Revit?
Thanks for your help
Brian
The Rhino.Inside.Revit installer for 2024 isn’t in the Stable Installer. We release 3 installers; Stable, Release Candidate & Daily Build. I send you a link to the Daily build.
I have the same issue with Rhino 8 and a trial of Revit 2026. Any way to work around this? Thanks
hai, i have same version too, it is impposibble with revit 2026?
The latest Daily build installs on Revit 2026.
Hi @brianorser,
Rhino.Inside Revit requires Rhino 8 to run on Revit 2025 and 2026.
