I am testing window placement and am having trouble to modify the opening dimensions.
I first duplicated the Default window, modified the Size (1.9 x 2.4m) then referenced a block to set at the opening. I moved my window to the floor level and the block is placed ok, but the opening size does not change.
You need to create a new profile with the _vaProfileFromCurve command to define the dimensions of the window. Aftewards, edit the window style and select the new profile in the geometry tab, as shown in the image.
