Modify windows dimension by gh
Is it possible to modify the VA windows dimensions directly by gh as a input?
Thank you
Hi @fn_a, do you mean a referenced window from Rhino?
You can create a new window in GH based on the referenced one and change one specific dimension:
Edit Window Dimensions
Edit Window Dimensions.gh (12.6 KB)
Thank you @fsalla,
but the window geometry obtained is “temporary” in Rhino preview, do you think a way to bake it automatically?
So I tried it and I I got a strange behavior (see attached)
test_window refresh
Thank you again
I think the problem is that the baked window takes the “Cut Depth” value to “None” by default, and for that reason it doesn’t generate the opening in the wall:
We will revise this behavior.
