VisualARQ 3 - Version 3.6 released
Hi everyone,
VisualARQ 3.6 is now available for :arrow_down: download.
This is a maintenance release that fixes most of the critical issues and crashes reported by users. Please report any problems or suggestions here or send us an email to visualarq@asuni.com.
List of changes since 3.5.2:
New Features (1)
  • Attributes:
    • 10877: Support Rhino 8 transparency
Improvements (1)
  • Level:
    • 13732: “Set Floor/Ceiling Plan” option doesn’t keep CPlane orientation
Changes (1)
  • Attributes:
    • 15160: Rename “Transparency” to “Opacity” in color properties
Fixed Errors (26)
  • API: Script:
    • 13107: GetSpaceCurve method is not returning any curve
  • Attributes:
    • 15083: Section style changes by Layer on VisualARQ objects don’t update automatically
    • 14141: Show background color (section styles) in Hidden display
  • IFC:
    • 15261: Distance display Units with V4 Engine is not detected correctly
    • 14806: V4 Engine doesn’t read custom parameters
  • Interferences:
    • 15124: vaExtractSolids does not extract solids properly
  • 14938: Core Slab Layer doesn’t cut wall normal layers
  • Level:
    • 14001: Elements located in other levels are displayed when activating the plan reference view
  • Object: Guide:
    • 14933: Guides can’t be stretched
  • Object: Plan View:
    • 15128: 2D Plan view doesn’t generate the Elevation mark 2D symbol
    • 15103: Wrong display color in some elements in a “Plan View” object
  • Object: Roof:
    • 15270: Window can’t be inserted in a roof created from a planar surface
  • Object: Slab:
    • 15085: Error copying a slab from one file to another
  • Object: Space:
    • 15095: Space label has changed the alignment from one version to another
  • Panel: Tables:
    • 15025: Read only parameters can’t get the totals in the Table report
  • Print:
    • 15188: Hidden parts of an object in RCP are printed
    • 15159: Printing errors of a RCP
    • 15094: Printing multiple layouts is very slow
    • 15051: Printing errors of a Reflected Ceiling Plan in vector output
    • 14898: Wrong RCP print result
    • 14862: Wrong print result of a RCP view
    • 14851: Model in section is not printed to PDF
    • 14850: Window openings are not printed well in a live RCP
    • 14703: Print issues of a RCP: Curve is not printed
    • 14357: Reflected plan views are not printed properly
  • View: Plan and RCP:
    • 15157: Wrong plan view after I Align Floor Plan in a Detail
Previous version:
Enjoy!
Enric
What is IFC V4 engine? Is IFC4 already?
The V4 Engine is the new engine developed for importing and exporting IFC 4 files. It also works to open IFC 2x3 files. The IFC4 import is already available. The IFC 4 Export is still under development.
Nice to know, so the IFC4 exporting seems to be near, right? :crossed_fingers:
Yes, the IFC4 export is getting closer.
dream about this feature for a long time, keep going, good luck!
