VisualARQ 2 - Version 2.4.1 released
VisualARQ 2.4.1 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Fixed bugs:
  • Some UI strings were not translated.
  • Inserted models with a different unit system were not scaled.
  • Section hatches were not printed in Hidden Vector Output when current layer was off in the detail.
  • Section view disappears after undoing a change on it.
  • Some meshes were not visible in Rendered viewports when they were outside of the viewport when the model was opened.
  • Update Property component left objects in bad state.
  • Missing hole in doors and windows that were inserted in the top part of the wall.
  • Slabs created from a NURB curve disappeared after moving a control point.
  • Wall joints were not correctly solved when calling VisualARQ.Script.AddWall() method from a C# Grasshopper Component.
  • Section views failed to compute when an object in the document had an invalid bounding box.
  • Wrong section line color was used in some cases.
  • Fixed an issue when canceling an import of an IFC file with errors.
  • Fixed stability and display issues after running vaSlabAdd or vaSlabSubtract commands.
  • Fixed a crash when opening files from VisualARQ 1.x in Rhino 5.
  • Fixed a crash when opening or inserting models in Rhino 5.
  • Fixed a crash when editing a VisualARQ object with history.
  • Fixed a crash when selecting an object after creating a new document.
  • Fixed a crash in Rhino 5 when importing a Grasshopper Style with Rhino 6 components.
Enjoy!
Enric
