ViewCaptureToFile freezing Rhino
Hi there, I was having in issue with Rhino when I tried to go to command ViewCapturetofile and upload my file with only my whole progress frozen in place and the file not uploading, at first I through it was the usage of the transparency but when I tried the same method without it, it still wouldn’t work for me. What should I do if I want to have a rendered photo with transparency in ordered to upload to photoshop with out any issues?
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Also, does this issue also arise in a new file from a factory-default template and just a simple box?
Here are the systeminfo:
Rhino 7 SR12 2021-11-9 (Rhino 7, 7.12.21313.06341, Git hash:master @ 5590153808223b57a9f41516a969fd949aa81bff)
License type: Evaluation, build 2021-11-09
License details: Stand-Alone
Expires on: 2022-01-25
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 8-20-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 3-10-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.92
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-10-2021
Driver Version: 27.21.14.6192
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.12.21313.6341
It arises in any format that I try use the commands.
I was wondering if someone could help me with my issue, I’ve been waiting for quite a while.
So Rhino freezes even when you try to view capture just a box in otherwise an empty scene?
Are you doing a viewcapture of the Raytraced viewport mode, or does this happen with other display modes?
It still would be useful to receive the file for investigation. You can use Rhino - Upload to Support to upload the file to our servers if it is big or confidential.
