View Capture to File does not save
Viewcapture to file and view capture to clipboard don’t give any results when not saving at the native viewport resolution…
Is something like a Material ID channel planned for the rhino render?
It works fine for me:
I just opened a file, set the display, ran ViewCaptureToFile using the default settings, gave it a name and here it is.
What are you doing differently?
The problem occurs, when I set a different resolution from the default.
can you replicate it?
Also the way view capture to file behaves is different to rendering, which makes a bit unuseful for my use case.
when the viewport is not square, but you want to save a square, the camera seems to zoom out instead of cropping, which rendering is doing. which makes view captures and renderings annoying to align in photoshop.
