Video & hardware info missing under OpenGL
So I have been using Rhino WIP…I recently checked the information listed under OpenGL in the options panel.
I currently have an NVIDIA Quadro P3000 - all fine there - but Rhino WIP doesn’t recognize it?
Rhino WIP shows:
Rhino 6 shows:
I don’t remember experiencing this before, so I don’t know what caused it - regarding my graphics card, I recently updated the NVIDIA driver to the “New Feature Driver (QNF)” instead of the “Optimal Driver for Enterprise (ODE)” because I couldn’t open/run an autodesk app (maya) until I did that. Different subject, maybe? But do you suspect it could be related?
Any potential solutions or related thread would be of great help. I like Rhino WIP and would like to continue using it, however I have noticed a significant change in graphics handling when I go into ‘rendered’ view with something as simple as a flat surface. Painful.
Thanks and happy Sunday
Hi - That is strange, yes. Does the SystemInfo point to the Intel as the Primary OpenGL device?
I would try a clean reinstall of the drivers but don’t know how Maya is going to like that…
hi @wim thanks for your response! systeminfo shows the quadro as the primary device - it’s also listed in Cycles when I’m in Rhino - if that matters.
Ok I will try a clean re-install of the drivers and report back.
Thanks!
ok @wim reporting back:
so I did a clean re-install of the NVIDIA driver and it’s all working fine now
both Rhino and Maya open up and run fine :ok_hand:t3:
strangely enough, though, my ‘re-install’ involved:
  1. downloaded driver from NVIDIA: didn’t work , couldn’t even complete installation
  2. let windows update through device manager: it worked
  3. updated the driver again through DriverEasy: all working
different problem, I guess, now, for NVIDIA to look into - if I went to NVIDIA to download a driver I had to provide specs for and it didn’t work :man_shrugging:
