I find that this command is problematic.
It seems to require two objects to modify before it will request and accept a source object, and it changes the modified objects’ layer to the active layer.
Va version 2.13.2.17721, Rhino 7 SR37
Hi @djhg (I’ve just rescued this forgotten question, sorry).
There is an issue in the component in Grasshopper that asks you t
The problem is that the “Get Geometry” components in the Grasshopper definition that runs with this command, prompts you to hit Enter twice after selecting objects.
I reported this issue some time ago: https://mcneel.myjetbrains.com/youtrack/issue/RH-74244/Get-Geometry-components-prompts-you-to-hit-Enter-twice-after-selecting-objects
This problem doesn’t happen with the other commands in the VisualARQ Labs because there is a different “Get geometry” component for VisualARQ objects that avoids this.
By the way, this vaMatchSectionAttributes command doesn’t work with the VisualARQ 3 version for Rhino 8.
