Get geometry component GH Player_Visualarq geometry
Is it possible to select a VA geometry via “get geometry” with the GH Player component?
(prompt command should be able to select VA geometry into Rhino View)
Thank you
Hi @fn_a, yes, that’s possible in VisualARQ 2.13 (we have released it recently).
You will find the VA Get Object component under the VisualARQ object Params:
Is it possible to find and select a VA geometry by levels?
Hello @miguelayora3,
Yes, you can do it with this Grasshopper definition:
Select objects by level.gh (10.5 KB)
Great! Thank you
Hi @alfmelbev,
Is it possible to select VA geometry by layers as well?
I tried this solution via Elefront but nothing
Thank you for any suggestions
Hi @fn_a,
Yes, you can do it with the Grasshopper file attached above, using the Layer filter in the VisualARQ Pipeline:
Select by layer and level
Thank you @alfmelbev,
but in my defintion I need to get the layer as a input from human ui component updated (see the previous image attached). So in your defintion the Va pipeline component is not able to receive a layer as an input.
Hi @fn_a,
You can use this definition instead:
Select by layer
Select by layer.gh (5.3 KB)
