The Floating command window is changing its location randomly. In V5 it stays at the place even after restart. @Gijs, could you please look at it?
Desired location:
Random place during the work:
After restart of the Rhino:
Desired location:
Thanks,
I see the same issue in Rhino 7, although it pops up at a different location after restart.
I’ll log to see if the position can be saved between sessions.
RH-83379 Command dialog location
It’d be helpful, particularly on a multi monitor setup. The pop up all over the place and often under other windows on other screens which makes finding em a real PITA.
