Command prompt stuck
Was trying to get the command prompt which was docked at bottom back up to the top. Then it started really misbehaving…
https://www.screencast.com/t/vjRRStfFKmue
And after that couldn’t even close the WIP with the X close box, had to type Exit at the command line.
All the panel stuff appears to be completely fubar at the moment… not ready for primetime.
https://www.screencast.com/t/pUJXkAasHTf
And now stuck…
https://www.screencast.com/t/hyTwJc6I3x
Hello?
I finally had to do a ToolbarReset to get the command prompt back at the top.
I can’t believe how incredibly buggy the new system is - practically impossible to dock anything where you want it.
https://www.screencast.com/t/j6CnLxw96
Once I learned about the new little lavender docking target zones, and the drag patch on containers, I’ve not had any issues.
That said, I don’t spend much time in Mac Rhino other than bug testing and seeing if I can repeat user reported problems.
I’m running on a 2019 Intel CPU MBP with an AMD Radeon Pro 5500M
I am learning this new system with you right now. I think you can’t get it to dock because you are trying to moving the toolbar which needs to plop onto another container:
If you want to dock it somewhere new, drag the container onto the lavender squares that appear in the corners:
Your command issue might be related to mine. Command apparently is a different kind of floating panel that can get lost or lock up the UI.
Hey Mitch -
I suppose that, from JBs response :see_no_evil:, you can tell that our days rarely have enough hours in them to watch a bunch of videos posted on some platform. There’s nothing I can do about that, I’m afraid.
As Eric noted, I’ve create a few YT items related to the floating command line panel, hopefully that snowballs positively…
I’ve added notes to RH-73767 and RH-73768 to test more when fixes for those get in.
