(bug) FloatingViewPort buggy / useless
Version 8 (8.13.24289.13002, 2024-10-15)
create a _newFloatingViewPort
the main Rhino UI will disappear.
reactivate Rhino
select an object in the floating viewport - selected object not highlighted…
Just try to do some simple tasks with the floatingviewport and you will see its buggy / useless.
thanks for a fix
kind regards -tom
Hi Tom, I’m seeing similar results as well, thanks for reporting RH-84324
Hi
In Windows, there is also the same problem.
I changed the bug report to both platforms but not able to repeat in windows. Please run SystemInfo in the Rhino command line and post your result, thanks.
“I’m sorry, I also couldn’t repeat it after today’s update.”
But there was the same problem before.
Thanks :pray:
RH-84324 is fixed in Rhino 8 Service Release 16
