Interface doesn't remember placement on screen
Each time I open Rhino, the interface is left floating on the desktop instead of re-instating the previous size and placement on the Windows desktop.
Then there is the floating bundle of panels with layers, properties, etc… that I need to close each time because I never wanted it there, never had it there… don’t want it !
Rhino is the only CAD I know that never could get such basic interface stuff to just work…
Aren’t you gonna ask me for my System infos as usual ?
Yeah, as I expected. The jiggling Rhino interface issue will just never get solved…
Hi, @osuire.
PROBLEM 1: Windows not saving Rhino 8’s window size & location
Possible Solution: Start > Display Settings > Multiple Displays > Remember window locations based on monitor connection (checked)
PROBLEM 2: Rhino not remembering container/panels visibility & locations
Possible Solution: Setup your Rhino 8 workspace as you’d like (containers, panels, toolbars, etc.). Then, in Rhino, use the SaveWindowLayout command. You can manage your window layouts with Rhino’s WindowLayout command.
Hope that helps!
It was checked on my system, and no, it doesn’t work
Does not work. The issue is not that my panel placement gets jumbled.
Rather, it’s that a stupid floating panel with a bunch off tabs is added for no reason, and floats in the middle of the screen.
I see, and you are correct, they should be working. Please call or email our McNeel Europe’s Tech Support, so someone can help you get the problem sorted. Rhino - Contact Us
Sure. That way, they can report back to you.
Well, I wouldn’t expect much from this. Windows 11 has absolutely the worst management of multiple monitors I have ever seen. Doesn’t matter if that checkbox is checked or not, do not expect any of your open windows/apps to stay put. This is not a Rhino problem, this is a Windows problem.
After sleeping and waking up I routinely find open windows that have been resized (too big or too small) and that have switched monitors. I have a feeling this might also have to do with display scaling. I sometimes end up with Photoshop covering a monitor and a half in both width and height - that is to say the bottom of the program window is way off the screen on the bottom. I also get some directories that might be open to end up at 100% display scaling when normally they should be at 150%. Etcetera, etcetera. If Rhino is using the same Windows functions to manage its placement, it’s never going to be right.
In fairness to Microsoft, the budget had to go on the swish screen zoom-out and lock effect that happens when it detects new monitors.
There was none left for actually functional operations.
@osuire McNeel shares tech support responsibilites based on the region the problem originated. I offered to help here, but since what would normally work isn’t, I’m elevating your level of support and directing you to the regional office responsible for helping you solve your problem.
Ok, that sounds like a lot of red tape to me.
Just fix the damn thing folks !
I suppose McNeel Europe reads this newsgroup too, right ?
@osuire We are attempting to help you. If you’d like to work against that, it’s your choice.
