V8 Popup toolbar doesn't keep its size
The popup toolbar has a different size (one extra column) when it pops-up than when its floating.
This pushes all the icons out of sync if they are expected in a specific location during use.
hi @ThomasAn can you send me your _SystemInfo? thanks
Same problem here. Seems like resizing of the Popup does not work like in R7 anymore. It´s frustrating for the workflow.
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Evaluation, build 2024-01-09
License details: Cloud Zoo
Expires on: 2024-04-24
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
.NET 7.0.0
Computer platform: LAPTOP  - Plugged in [100% battery remaining]
  Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 4-16-2020 (M-D-Y).
    > External USB display device with 2 adapter port(s)
  Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 2-10-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.79
Secondary graphics devices.
    > External USB display device with 0 adapter port(s)
        - There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
  Safe mode: Off
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 8x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 2-10-2022
  Driver Version: 30.0.15.1179
  Z-Buffer depth: 24 bits
  Total Video Memory: 6 GB
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
Hmm, I cannot reproduce that here in an older version, nor in the latest in house.
But there is this open issue regarding the size of popup toolbars:
RH-78836 PopUp sizing
Its the v8 version on the McNeel site. Downloaded yestedday.
It could be a Windows 10 only bug, but have no Win 10 box to test here right now.
If it was a windows thing, then v7 would also struggle. (then you’d also have to ask, what did v8 forget about windows that v7 knows ? )
@ThomasAn
V8 was largely rewritten to be cross-platform compatible between Windows and Mac.
IMHO, there was inadequate WIP/Beta testing for all this new code, so we’re playing catchup as fast as we can.
If you’re more comfortable with V7 in it’s mature state (36 rounds of fixes), then maybe use it until the V8 fixes are farther along.
Be well
My thoughts too. V7 seems fine for now.
On further inspection, this part is completely broken. It is not just one column, it’s all of the columns, the popup seems to have a fixed size of it’s own.
Yup. That’s on the to-be-fixed-soon pile too.
Actually, this has been reported multiple times and is on the developer’s “Open” list.
Bringing this one back up from the bottom of the deck.
I’ve been editing my pop-up toolbar, and all has been fine (also exporting out to save it just in case.) Updated to the 11/6 release yesterday, and all was working fine all the way up to just now. The pinned version is the correct one. Tried multiple things (making bigger, making smaller, size to fit content, even lock docked containers on and off cuz you never know :person_shrugging: )
Sys info and image below.
Thanks,
Alan
SysInfo
Rhino 8 SR13 2024-11-6 (Rhino 8, 8.13.24311.03001, Git hash:master @ b6593276781d516da56f01162c4db7dda67089d0)
License type: Commercial, build 2024-11-06
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 63GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4080 (NVidia) Memory: 16GB, Driver date: 9-26-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 565.90
NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 9-26-2024 (M-D-Y).
- Secondary monitor attached to adapter port #0
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 3-12-2024 (M-D-Y).
> Accelerated graphics device with 5 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 9-26-2024
Driver Version: 32.0.15.6590
Total Video Memory: 16376 MB
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\OctaneRenderForRhino (f109bd23-4cf3-4c0b-9f83-06be474b0152)\2024.1.0.142\RHI Installer 7\Rhino 7.0\x64\OctaneRenderForRhino.rhp “OctaneRenderForRhino” 2024.1.0.142
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.1.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Cephalopod\0.0.3.0\Cephalopod.rhp “Cephalopod” 0.0.1.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Garage\8.7.24140\net7.0\Garage.rhp “Garage” 8.7.24140.15431
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24311.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24311.3001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24311.3001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24311.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24311.3001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24311.3001
@Alan_Farkas that’s odd, do I see correctly that the icons become larger when popped up?
Prob just because one is a screenshot within the screenshot… :slight_smile:
@Alan_Farkas could you run _Reset and click the “save settings for support” button and pm me the resulting zip? Thanks!
@Alan_Farkas
Thanks for sending the file.
I could reproduce the issue here.
What’s interesting is that if I make a new RUI fille, and copy the buttons to a new toolbar, I am able to make the size stick. I will send that in pm
Same issue here on R8 Windows 10. The popup toolbar loses its charm if we can’t open it the right way and at the right size.
I never had this problem setting up and using R8 across 4 different computers until I got a new system at work this week. When using my previous laptop, I can resize the popup toolbar and Rhino remembers the new size when I close and reopen the popup. However, when I use the fresh install on the new computer (with options/toolbars/popup settings imported from the laptop) the popup toolbar always reverts to 6 columns rather than the 7x4 layout that my muscle memory reverts to. Any ideas why this is a problem for different instances of R8 SR26?
No specific fix was found, but I wiped my computer and did a clean install of everything and the popup resize is working now.
RH-73095 is fixed in Rhino WIP
