Small POPUP toolbar issues
1.) I’ve added two buttons to change Gumball alignment.
When I go to EDIT TOOLBAR BUTTON those buttons aren’t named properly, ie they don’t inherit the name from the text? They’re called Macro4 which means nothing.
2.) The POPUP window keeps resizing itself. Why doesn’t it keep the size I configure it at?
Bump on the resizing issue. Is there any way to force the popup to keep the size you set it at? The whole point is quick access to frequent tools & building muscle memory so you don’t have to think about where those buttons are. But without the ability to keep popup proportions - new buttons move everything around so every time you add / remove from the popup you can’t rely on muscle memory anymore.
Same for me, I’d like to see the popup toolbar maintain it’s sizing, or at least not collapse and place the last few buttons in a fly-out menu.
Bump. Please is there any way for the popup toolbar to stay at the sizing that it’s set to. Not sure who to tag here - @dale ?
@steve and @CallumSykes are currently working on toolbar issues. This is a known problem.
for toolbar issues feel free also to tag me, then I’ll write up a YT for it. In this case, the issue is known and listed as
RH-84339 popup toolbar size is off with text button
I’ve added this thread
Note that my MMB popup also changes sizes when I save the custom .rui that it resides in. I have sent the relevant info to Steve and Callum. Don’t know if this is related or not.
Just want to bump this thread. The popup toolbar should stick to the size that it’s set to when in configure mode. The whole point of a toolbar is to build muscle-memory. With this Popup every time I add something icons move around. I also prefer the wide layout, but it always default to its own vertical size layout.
Popup toolbar:
Popup configuration (this is how the Popup toolbar must look - same as this):
@Gijs This issue persists even without text labels. Rhino doesn’t respect set popup size / layout. Here’s using standard Rhino toolbar icons.
