Rhinoceros 8 - Popup toolbar resized
Hello good fellas,
I am experiencing some issues after upgraded my workstation to Rhinoceros 8. The problem is the changes due to toolbars/containers.
I made a small video that shows exactly what I mean. I resize the popuptoolbar and the next time i use it, it doesn’t follow the size I reshaped it before.
Known problem. Will be fixed… sometime.
Workaround: RH8 - Popup - size setting
I wish that is really on of those that get fixed… not forgotten :slight_smile: ehehehehe!!!
Thanks 4 your reply!
Seems it is in current SR3.
Well, there is a workaround after the release candidate, it was fixed, probably by a “collateral damage”. After you properly set that window layout, you use Size to Content. Then after close it you will see it next time as you wished it to be :slight_smile:
RH-73095 is fixed in Rhino WIP
