Kind of. Parts of the functionality made it but offsetting a face did not. The gumball was already quite complicated and it took a lot of work to keep it as simple as possible while adding the new features. There’s a pretty good video on the new functionality here:
Thanks
Something like In Sketchup to quickly use PushPull
For example PushPull mode , and when it’s activated we can use it without need to type the command every time just select the surface and push/pull
Or a button to toggle it on
But if PushPull remains active and is not used as a command, it is better. This is because, when selecting new faces or changing the cplane, we need to run *_PushPull again.
Making it always active by choice is better, like Auto CPlane.
Can the cplane change automatically based on cursor position without click on the face? This is useful when we draw curves on the faces.
Hi @Gijs
Is it known that the icon for PushPull needs a touchup to be properly visible on dark mode?
The guys in the icon could be white/light grey. instead of just the grey stroke… or if you make the grey stroke lighter [like the shade of the text in the status bar perhaps…
