This is an attempt to create a single window modeling environment with a dynamically updating cplane. It will snap to ortho views, and if released will lock there. You can release it by holding down shift+ctrl, which will return it to a rotatable viewport.
start with the default settings and play with it as you like. Please post your thoughts or suggestions for improvements here.
Iâve been waiting for this one (and I guess itâs been in there for a couple weeks nowâŠ).
I was afraid that the implementation wouldnât allow the settings to be as an earlier script by Pascal and that seems to be the case now.
I would really like it (to the point where I will not use the functionality as it is now) if one could have the World CPlane as the primary CPlane. That means that in order to activate another CPlane, one needs to get within 10Âș of that new CPlane (as it works now) but that when the view is off 10Âș of that new CPlane that the World CPlane again is the active one. Just like it was in a previous version of the script.
Iâve just played with it a little here, but I like it and think it has promise. I canât yet tell if it will become intuitive or annoying. Iâve not played with different angle settings yet. I find the SHIFT + CTRL release to be easy enough.
I find it a touch unnerving that sometimes when it âlocksâ into parallel mode that the model disappears until the mouse is released.
My only comparison for this is the way that solidworks uses a key combo (CTRL+Arrow keys) to flip into the different ortho views. I quite like that implementation, as well as the satisfying animation between views (much like ViewRestore).
Anyway, nice to see some work happening on this.
EDIT - just a thought: could this not be engaged by just using the CTRL + SHIFT when nearing an ortho view? I realize subselection might get confused here.
I agree, Iâm leaning toward wanting the snap to ortho NOT being automatic, but free rotating unless you want it to snapâŠIdeally holding a key or key combo would temporarily enable it to snap and the same key or combo would then unsnap itâŠ
