Use of kangaroo2 with rhino points
I’m trying to find the form with kangaroo2 starting from some points I have on rhino.
Surely I’m wrong in the code and the convergence it finds is not what interests me.
I am attaching the file with the points and my code.
Thanks so much!PUNTIdm.3dm (256.4 KB)
MESH.gh (18.3 KB)
musmeci.gh (17.3 KB)
It looks like you were trying to find the right points from your flat mesh to pull to the target points?
It also seems to me that there are a lot of points anchored inside the mesh here, not just at the boundaries. If you want to form-find this as a tensile net, I think it makes more sense to only anchor the external points (since in the actual built compression structure those are where the deck loads and reactions are applied).
