This causes Rhino to slow so much it’s essentially non-functional:
However, I tested it on a different machine, and it seems only a very specific width causes that glitch?
sloooow.3dm (1.6 MB)
I can’t repro that here, but maybe when I get the exact same setup as yours. Could you run OptionsExport and send the resulting .rhs?
I didn’t get a .rhs, I got an .ini?
Also, this is on a 1440p screen. I’m guessing it will look and behave different on a different resolution as well.
hi @eobet sorry, my head is 100% in Rhino BETA,
I doubt the ini will work, I guess I need the WindowLayout (the .rhs in Rhino 9 will save all of things UI)
Window > Window Layouts > Save Window layout
Shown here in Rhino BETA, but that should work in 8 too.
Not sure why that file is 14mb large…
This is on the list as RH-98779 Hyperlink in Properties panel makes Rhino unusable
-w
So this won’t be fixed in any SR for V8?
Hej Robert -
We’ll give this a shot → RH-98779 Hyperlink: URL in Properties panel makes Rhino unusable
RH-98779 is fixed in Rhino 8 Service Release 37
