miano
(Miano)
June 26, 2024, 2:21am
1
This is a bug I have seen since V8 came out but I am finally annoyed enough to write.
That is, the Properties panel stops updating for an extended period of time. Usually, when this happens it displays the viewport properties. Here I have a text box selected but the properties panel does not show the text box..
I sat and waited three minutes and the panel updates on its own.
It looks like there is something going on in the background that blocks the properties panel from updating.
I have also seen this where selecting object-1, then select object-2, and object-1’s properties sit on the screen for a minute or so. However, this is much rarer than seeing the display properties being displayed.
miano
(Miano)
June 26, 2024, 8:27pm
2
A little more information, in this scenario:
Click Object-1.
Click Object-2 => Property panel does not update immediately.
Wait for a while
Properts panel updates
Object-2 is unselects on the screen.
Making changes to the Properties panel updates Object-2 even though it does not appear to be selected.
Japhy
(Japhy)
June 26, 2024, 9:01pm
3
Interesting, can you run SystemInfo in Rhino and post the result as well as the file? I’ll try to repeat.
If it proprietary you can send it privately here…
Thanks
miano
(Miano)
June 26, 2024, 9:03pm
4
It doesn’t happen all the time. It’s intermittent.
Rhino 8 SR9 2024-6-19 (Rhino 8, 8.9.24171.03002, Git hash:master @ c7bc7dce8c2b456b3f0c5f0fa669295aa802ef1a)
License type: Commercial, build 2024-06-19
License details: Cloud Zoo
Apple macOS Version 14.5 (Build 23F79) (Physical RAM: 64GB)
Mac Model Identifier: MacBookPro18,2
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.9.24171.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.9.24171.3002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.9.24171.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.9.24171.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.9.24171.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.9.24171.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.9.24171.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.9.24171.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.9.24171.3002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.9.24171.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.9.24171.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.9.24171.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.9.24171.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.9.24171.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.9.24171.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.9.24171.3002
Japhy
(Japhy)
June 26, 2024, 9:05pm
5
Thanks, even if i can’t get it reproduced for a bug report, posting the info is helpful and will be reviewed.
miano
(Miano)
June 27, 2024, 3:46am
6
Here’s another example. I’ve selected a text box.
Then I select another text box, but the properties for the first text box are displaced. If I change the text, the first text box gets updated.
I select a dimension and the same thing happens
This took 3 minutes for Rhino to update the properties.
miano
(Miano)
July 3, 2024, 8:44pm
7
Am I the only one seeing this?
I am getting it constantlly now particularly in layouts.
I frequently have to switch to a view then back to the layout to get Rhino unjambed here.
wim
(Wim Dekeyser)
July 4, 2024, 7:36am
8
Hi John -
Please upload a file so that we have something to work with.
miano
(Miano)
July 4, 2024, 5:44pm
9
I updated one (of many) where it occurs frequently. I do a lot of text editing, layer changing, and style changing in a layout. Then Rhino either has a long delay between selection and updating or does not update at all.
When the latter happens, I have to switch to a view then back to the layout to reset.
mary
(Mary Ann Fugier)
July 5, 2024, 10:44pm
10
Hi @miano ,
We tested your model here and experienced no issues with the Property panel.
We were testing with Rhino 8 sr10 WIP that will be out Wednesday as the release candidate.
See the performance we have getting with your file in this video .
We can see you took your screen captures from the Top model viewport, so that is where we tested.
Since is happening sometimes and then not others, and since it is obviously not following the file, we will need you to keep any eye on it.
And you can test with the SR10 Release candidate next week when it is released.
Let us know if you come up with any details on how to duplicate the behavior on our computers. If we can duplicate the issue on our computers. then we can write a bug.
Thanks for your help.
Sincerely,
Mary Ann Fugier
miano
(Miano)
July 5, 2024, 11:03pm
11
I see it more commonly in the the layouts. 1:192 is the one I used more recently.
I have not yet found a sequence that causes the problem. I just seems to happen after a period of time,
mary
(Mary Ann Fugier)
July 8, 2024, 7:38pm
12
Hi @miano ,
I worked with this some more today in your file and on a layout set to 1:192.
But never reached the point where the issue occurred.
See video here .
Throughout the session the speed of editing with the panel remained snappy and as expected.
These are very difficult issues have.
Keep your eye on the trigger.
If you come up with something repeatable, let us know so we can try it here.
Sincerely,
Mary Ann Fugier
miano
(Miano)
July 9, 2024, 10:50pm
13
The Mac Gods must hate me.
miano
(Miano)
October 18, 2024, 5:36pm
14
I am having this problem constantly.
Whatever notifies the panel of updates is not getting the message across.
miano
(Miano)
May 15, 2025, 2:07pm
15
Here is a screen recording showing the problem. I am having this CONSTANTLY where the properties panel stops updating.
wim
(Wim Dekeyser)
May 16, 2025, 7:49am
16
Hi John -
Can you post your updated SystemInfo data?
miano
(Miano)
May 16, 2025, 10:55pm
17
Rhino 8 SR20 2025-5-13 (Rhino 8, 8.20.25133.14002, Git hash:master @ 007e608777fd819d8976799b8426698dff88c962)
License type: Commercial, build 2025-05-13
Apple macOS Version 15.4.1 (Build 24E263) (Physical RAM: 64GB)
.NET 8.0.14
Graphics processors
Apple M1 Max
GPU Vendor: Apple
USB devices
Apple Inc.: iPad
Bluetooth devices
None
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftPassKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.20.25133.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.20.25133.14002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.20.25133.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.20.25133.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.20.25133.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.20.25133.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.20.25133.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.20.25133.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.20.25133.14002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.20.25133.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.20.25133.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.20.25133.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.20.25133.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.20.25133.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.20.25133.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.20.25133.14002
wim
(Wim Dekeyser)
May 21, 2025, 2:52pm
18
Hi John -
… but I assume that’s not the case when you restart Rhino, start a new file with two curves on two layers and select those one-by-one?
Does it happen during the course of any model session? Do you exit Rhino at the end of the day? Does it also happen when you only have one file open?
miano
(Miano)
May 23, 2025, 3:18pm
19
Restarting Rhino ends the problem.
I have seen the problem with one file or multiple files. If I have multiple files open, switching files tends to immediately update the properties panels when i switch back.
I sometimes keep rhino going for a multiple days.
miano
(Miano)
August 24, 2025, 12:26am
20
I got a new mac and have the very same problem. After a while of use, Rhino takes forever to update the properties panel when I select a new object. This causes all kinds of annoyances. In addition to long delay, if I don’t notice the problem I end up changing properties for the wrong object.
