neither the automatic update of R9 or the standalone update (by downloading the file) works at the moment.
Could you please fix it?
(As far as I know there’s no problem with my internet connection here.)
Thanks
/Erik
Thanks
/Erik
It worked here half an hour ago.
Just downloaded (manually) and installed the latest WIP this morning, everything appears to be working correctly - here at least.
I downloaded the packages manually. That worked. I copied the “rhino_en-us_9.0.26097.12305.exe” file to the “redist” folder and ran the installer as an Administrator.
It stops here.
I’'m not 100% sure it understands that all the packages are in the “redist” folder …
What can possibly be wrong ?
/Erik
Quite a big problem.
Uninstalled WIP.
Tried again. Did not work.
Restarted computer removed folder in Program Files.
Installation started. But ended with:
Rhino_WIP_20260420112206.log (41.7 KB)
Please - does someone have a clue about this ?
/Erik
Try repairing the Microsoft Visual C++ Redistributables
Thanks.
This solved the issue.
It did not prompt me to restart and I tried without. But the installer did not work.
I restarted. Then it worked fine.
Great! Thanks for helping out.
/Erik
it is still impossible for me to update Rhino.
Offline mode does not work.
Neither new downloads from McNeel.
What can we do about this?
(I can’t run R9 at all at the moment, it is not starting.)
Thanks
/Erik
