Unit mismatch between Rhino (mm) and Karamba3D (m)?
I am using Karamba3D in Grasshopper to perform a shell analysis.
When I ran the analysis, I noticed that the displacements were unrealistically large.
In Rhino, my model units are set to millimeters (mm). However, it seems that Karamba3D internally interprets the geometry in meters (m).
How can I properly resolve this unit mismatch?
Do I need to scale my Rhino/Grasshopper model by 0.001 before sending it to Karamba3D, or is there a recommended way to handle units within Karamba?
Thank you very much for your help.
Hi, you can change the geometry input units in the menu: 2.3 The Karamba3D Menu | Karamba3D v3
Hello Matthew Tam,
Thanks to your help, the issue has been resolved.
I truly appreciate your continued support.
Thank you very much.
Best regards,
Akira
