Hello everyone,
As you can see from the model, the displacement should be 43 cm, not 0.43 cm. I understand that I can change it with an expression, but since Karamba and Rhino are set to meters, my question is: why is the maximum displacement shown incorrectly, and how can I set that right?
Dear @cem_cetin1,
you are currently using a version of Karamba3D that still includes the Settings component. In newer versions, this functionality has been moved to the Grasshopper/Karamba3D menu, where settings like units can be adjusted directly.
The change was made because Grasshopper does not guarantee the execution order of independent component graphs. With the Settings component, this could require running the definition twice to apply changes correctly.
I would recommend updating to a more recent version of Karamba3D.
– Clemens
