I have a very detailed surface as a brep from a sculpture. The units are in Rhino in mm. The sculpture has a base area of about 1100x800 mm. I know that Karamba work in m by default. However, if I scale the sculpture by 0.001, the mesh is displayed incorrectly in Karamba. I think that then simply the decimal places become inaccurate. In the .ini file of Karamba I have actually already changed the units to mm, but that doesn’t change anything. When I put a cross section on the mesh, the sculpture weighs 80.000.000 kg. Even if I then divide the cross section by 1000. So something is wrong there.
Is it possible at all in Karamba that I really work with mm? Does anyone here have a tip for me? Thank you very much.
Best regards
Peter
