Hi, Two posts I get no answers on.
I must say I haven’t seen these questions asked here. Not recently anyway.
Have you tried the following? I just tested, seems to work fine
I’ve seen the update problem many times. Just filed a bug for it: https://mcneel.myjetbrains.com/youtrack/issue/RH-41570
I had the problem on an in-house build from Friday. This morning I downloaded and installed a newer one that fixed the problem for me. It is impossible to tell from the application if the error is on the workstation end or on our server side.
